Not receiving Battlenet Authentication Codes
SebastianS
After several attempts and confusion and switching my number between two Battlenet accounts, Now I have sorted the two account issue, I am no longer recieving authentication codes from Battlenet (on either account, or on my now only account)
I put in a ticket with them, and tried things such as clearing my messages cache, deleting the number they're sent from, checking my blocked messages, and changing APN I am still not recieving the code
Battlenet said they can't help anymore with the issue, and to contact my provider
I am recieving other messages, and authentication texts, but they're insistent that the issue is on my end. Is there some blacklist that the authenticator could have been put in, and a way to undo that?
Why is this happening, and how can I fix it?
1 REPLY 1
fixin1
@SebastianS - If you just ported in Battlenet's 2FA Server must have a port protection - a thing most 2FA things have in place to protect your account. Also if you just ported in you may have a port issue, please check your old SIM card.
Also what plan are you on? Some Canada Only text or Incoming SMS only plans don't allow shortcodes or international numbers texting you.
If you believe you should contact Public Mobile, submit a ticket with them here:
Submit a ticket via Chatbot:
⚠️ Public Mobile is Experiencing longer support wait times currently! Do Not Reply back to CS_Agent after submitting your ticket unless you solved it! Click here to bring up the Article!   ⚠️
⬇️  Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
