Subscription for 20GB data appeared in my account.
Blackbearwhite1
Hi, this month a subscription for 20GB data appeared in my account. I am not aware of this. Can you please check what happened? I do not need this add-on/subscription. How can I cancel this as my credit card was charged today(this is how I found out about the add-on).
Thank you for help,
Florin
2 REPLIES 2
Chalupa_Batman
Hello @Blackbearwhite1
A solution has been chosen however there is no response of what happened. If @maximum_gato has given you the solution, can you please reply and let us know what happened? Every response helps us helps others. Thanks.
maximum_gato
@Blackbearwhite1
Is it possible that you accidently replied YES to a promotional text when you meant to just delete it? It's happened to others because pm leaves a pre-filled YES to respond with that gets tapped accidently instead of swiped away or deleted. Check your shortcodes from pm like 5129, 5213 most likely.....
Edit:
If so or if just a weird glitch contact customer  support and explain the situation and ask them to return you to your original plan and credit your account the overcharge.
