Subscription could nit activate
AbeEnns
Subscription wint active say get support
2 REPLIES 2
@AbeEnns  Here’s how to get support right away to help
send  a  private message   To CS_Agent
hi @AbeEnns
if you are activating esim, reboot the phone and check if the esim already there on your Settings-> Cellular screen or Sim Manager.  Enable it
if you are activating physical sim card, test it on a phone
if that does not work, ask support agent to help.   you can submit  ticket by direct message:
