Subscription change
Chijioke123
If I change my plan, I will be refunded for the the formal plan that just started 3 days ago?
2 REPLIES 2
Phil_Adelphus
@Chijioke123  No there is not normally any refund, which is why it is recommended to select "Change on Renewal" rather than "Change Now" when selecting a plan change.  If you choose "Change on Renewal" the new plan will kick in at your next renewal date.
fixin1
@Chijioke123 - No, I will recommend to use the Change On Renewal button so then the new plan change will occur when your old plan expires.
