Subscription billing?
GC_the_man
Just got started on PM. Is my subscription auto billed and debited monthly on my credit card?
GC_the_man
Thanks for the clarification!
Sansan
It should be, but if you want to confirm, you'd need to sign in your self serve account and it should have a message indicating that you are subscribed.  You will see the last 4 digit of your card and the expiry date.
Socrates8567
@CSA_PM wrote:
Yes! Your PM subscription is automatically  debited from your credit card each month, so you can enjoy uninterrupted access—just make sure your credit card remains active and registered in your account.
Actually @CSA_PM and @GC_the_man  that is not 100% correct. You are billed every 30 days, not monthly. Therefore it will not be on the same day every month. But yes, if you have a credit card registered, as long as it's active, the charge will go through.
CSA_PM
Customer Support Agent
