Subscription Plan
11-26-2024 08:22 PM
Would like the $29 Canada -US-Mexico plan but it won’t with four existing customers. Is there a way we can get this plan?
Plans
11-26-2024 09:23 PM
Although you can ask , but some did and got declined
11-26-2024 08:49 PM
Thank you both!
11-26-2024 08:46 PM
HI @Wlaw
you can try to contact Support. While there has been successful cases, but some reported they got declined. But you can still try
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
11-26-2024 08:44 PM
@Wlaw Can try support we are just customers they might help ya
11-26-2024 08:43 PM
Thanks! I’m hoping to get the $29 one. My friend said she was able to get it by contacting someone here 😞
11-26-2024 08:24 PM
HI @Wlaw
what plan do you have now?
You don't see it now but there is a workaround to unlock it if you see the $30 plan there on your My Account
You can first pick $30 plan and do a Change Now plan change , which of course you need to pay now and the remaining days on your current cycle will be wasted. With this, you might be able to unlock the $35 roaming plan, and you can then schedule a plan change on the following renewal day
11-26-2024 08:24 PM
@Wlaw No sorry if it’s not available to change to in your account your outta luck , if you really want the MEX plan the $35-$45-$55 MEX plans should be there
