01-16-2024 08:38 PM
How can I stop my subscription with PM and switch to another provider?
01-16-2024 08:41 PM
@YS19 I believe you want to move your number to another provider
To port out, you start the process from your new provider
But first, make sure your PM account is currently active and you can receive text without problem. Login to My Account and get the account number from Profile page https://myaccount.publicmobile.ca/en/account/my-profile
While you are at My account, you might want to also disable Pre-Authorized payment just in case.
Go to Payment page, click Manage Subscription, then turn "Subscribed" to off
01-16-2024 08:40 PM - edited 01-16-2024 08:41 PM
@YS19 Just port your number out to new provider and it will automatically close your public mobile account . And if you don’t care about the number you can turn off auto pay
Turn auto subscribe off/on
Or get support to remove the credit card on file right away
send a private message To CS_Agents
