Subscribing
Queenie3
Trying to subscribe but stuck at step 6, not receiving an sms to port number
Queenie3
Issue solved
CSA_PM
Customer Support Agent
Hi @ Queenie3
Was the issue resolved?
hi @Queenie3
try reboot the phone and login to app again and see if you can complete the subscription
and if you are activating eSIM, can you double check if the PM  eSIM is already showing up on your Sim Manager or Settings-> Cellular?
if yes, then you need to manually enable it and set it as Primary (please also remove old carrier sim card and disable old carrier esim)
but if you still cannot complete subscription or sim not there, ask PM support agent to help, you can submit  ticket by direct message:
