12-14-2023 10:50 AM
I activated my service Tuesday night but in a limbo with my EversafeID - it says to reset my pw and a new one will generate, however, I CANNOT RECEIVE calls and texts, can only MAKE THEM
How am I supposed to resolve this since I cannot receive calls or texts?
12-14-2023 10:57 AM
HI @Biscayne05
it is the porting not done and hence you are not receiving text and cannot login. Put the login aside first and let's get the porting completed. I will send you a number to call the Poring support team, they will fix it for you. Please check your Community inbox
12-14-2023 10:51 AM
Please send a message to customer service representative at the link below to fix.
