SIM card
Julie67
When can I expect to receive my SIM card?
2 REPLIES 2
CharlieWhisky
Hi, it can take up to 15 days to receive the SIM card. If more than 15 you can contact a Public Mobile agent by private message
CS_agent will reply to your Community inbox within 2 to 4 hours. You can check your inbox here:
Sansan
How long has it been since you ordered it? If it does arrive,  it can take up to 10 business days or 3 weeks.
So you can keep waiting a bit more.
If it's been longer or you need right away, buy one from Amazon.
Or check any local Telus/Koodo/ mobile Klink store and purchase one right away.
