04-15-2024 01:35 PM
Hello,
I'm trying to activate my new sim card I received in the mail, and I'm using the Public Mobile App as instructed.
When I'm trying to login to my account on the app, I enter my e-mail and password, I received the 2-step authentication code, and when I click continue, it loads and brings me back to the login page again.
I was told I can't activate my new sim card unless I do it on the app, but I can't even login on the app. I'm using an iPhone 7 running the latest iOS software is that matters.
Any suggestions?
04-02-2025 06:56 PM
12-02-2024 04:30 PM - edited 12-02-2024 04:31 PM
Thank you or this! Too bad the app doesn't detect that it is too inept to use anything but Chrome. Imagine how much time and aggravation would be saved if it just notified the user that it could not use the default browser. And to think someone somewhere probably got paid to develop this digital garbage.
04-29-2024 09:33 AM
Not sure if this is applicable. I was having a similar issue on a Samsung android phone. I found I had to change the default browser in the phone settings from the Samsung browser to Chrome. The login screen is basically a web popup, and the Samsung browser was not handling the login correctly. Perhaps if you toggle this setting on your phone it may help too, even if you are using Chrome as your default browser already, maybe trying Safari will be better, or vice versa.
04-15-2024 01:40 PM
HI @BorisBago
try uninstall the app , reboot phone and reinstall the app and test login that way
if you really cannot login, I think you will need support agent to help and help you to link your sim card to your account
please submit a ticket by direct message:
