Stream+
Stephur85
Has anyone switched from TELUS who had the Stream+ bundle with them?
Does the service continue? Or did you need to switch it as well?
1 REPLY 1
hi @Stephur85
according to Telus, If you cancel your TELUS service, you will lose access to Stream+ immediately, and your subscriptions to services like Netflix and Disney+ will resume.  So, you will need to manage them separately. You may receive a pro-rated credit for any unused portion of your billing cycle, depending on your location.
so, you will need to resetup one using the Public Mobile offer, which subscribe via Koodo
https://www.koodomobile.com/en/shop/subscriptions/public
