Stolen Phone - Blacklist?
KarenC
Hello,
Recently, I got my phone stolen and have already suspended my phone. However I would like to blacklist the phone so they would not be able to resell it to others/stores. Is that possible?
Thank you.
@Amanda9 wrote:
How do I get my phone blacklisted
You would need to open a ticket and have a moderator add the phone's IMEI to the national blacklist. A ticket is opened by going to: https://publicmobile.ca/chatbot
Amanda9
@Carld123 wrote:
@KarenC wrote:
Hello,
Thank you.
@KarenC
Hopefully you have or can get the imei number for your device...call the cops if you want.. Report it stolen...get a case number..call your provider..give the imei and case number to your provider....blacklisted....
I have only ever reported a lost device to Telus.  I gave them the phone number and they were able to pull the IMEI from their system.
will13am
@KarenC, to add your device to the blacklist, you will need to reach out to the moderator team.  The moderator team can be reached via private message using this link.  Refer to the following knowledge base link for additional information on contacting the moderator team.
Carld123
@KarenC wrote:
Hello,
Thank you.
@KarenC
