04-23-2024 07:35 PM
I came over from telus where I had activated a "if you want to reach this person, dial (x) to be put through now."
It blocked all the robocalls, and was efficacious as proven by the conspicuous increase in these calls since I switched. Does PM offer a similar feature. And if so, how do I get to it/activate it?
04-23-2024 07:40 PM
No such option exists here, @Animalrb
My recommendation is to NEVER answer any calls from numbers/people you either don't recognize or are not on your contact list. It can be difficult to ignore a call, but you will get used to it.
If the person calling you needs you that badly, they will leave a voice message; if they don't bother leaving one, you likely didn't need to hear from them in the first place.
IF YOU DO ANSWER, and the caller is a spammer, it's likely your number will get logged as one which will get answered, so anticipate spam calling to increase (at least in the short term). Additionally, companies sell information to others for numbers which result in answered calls, so also bear that in mind.
04-23-2024 07:37 PM - edited 04-23-2024 07:38 PM
@Animalrb sorry, no call control option with PM. PM is a Tier 3 provider and only provide basic call features and call control is not one 😞
