04-18-2021 04:45 PM - edited 01-06-2022 01:50 AM
Not sure if this problem is just with me, I'm a new user and the public mobile site will often freeze. My PC is not dated, every other site works fine however the public mobile site is quite slow and gimmicky, and will sometimes freeze.
04-29-2021 12:27 PM
That's just a public mobile website issue. I've experienced it as well. Sometimes it can be really laggy and glitchy and just wont let you log in. But you just have to wait and try again at a different time/day.
04-18-2021 05:12 PM
Indeed it's a bit of a running gig around here that the public mobile self-serve site is hit-or-miss.
Coincidentally, they seem to have been making some amendments to the self serve site which might see it becoming a little more usable.
Hang tight!!!
04-18-2021 05:01 PM - edited 04-18-2021 05:02 PM
@ahmad-r wrote:Not sure if this problem is just with me, I'm a new user and the public mobile site will often freeze. My PC is not dated, every other site works fine however the public mobile site is quite slow and gimmicky, and will sometimes freeze.
@ahmad-r Yes unfortunately PM's website can be glitchy...usually waiting an hour (or less) and retrying will help. Also make sure to clear your cache/cookies and use a new browser with incognito/privacy mode enabled.
Everything seems to be loading a lot quicker than normal for me right now...so just retry again.
