01-28-2021 11:14 AM - edited 01-06-2022 01:57 AM
01-28-2021 11:28 AM
Hi @1002750718
Please click on the chat bubble (SIMon chatbot) on the lower right of screen and type
Need PUK
From there, select from the items listed, and follow the exact options/directions provided.
01-28-2021 11:23 AM - edited 01-28-2021 11:23 AM
Below is a post from another thread from the Oracle Luddite:
The following should help to delineate the various PIN messages that can occur:
"SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. As noted by @Triguy Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
Once the PUK is recovered and validated, you will be asked to choose a new PIN.
Only Public Mobile's moderators can give you this type of code, which the device manufacturer cannot. Public Mobile's moderators can be contacted by submitting a ticket at: https://publicmobile.ca.ada.support/chat/
Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
