Sims card
JR63
I ordered a Sims card and was supposed to receive it July 18th. How can I get a tracking number to find out were it is?
@JR63
Members have indicated that it took up to 10 business days to 3 weeks arrive.
It would have been cheaper and faster if you ordered from Amazon for $4.99.
slusagm
The 2 days shipping note when you ordered was about how long PM will fulfill the order, not when you will get it
 But if you order around July 16th, you should received it late last week or early next week
But check with PM first before you go out and buy another one.  Tell them you can't wait longer and push them to reimburse you if you buy another one elsewhere
You just need to open ticket with them.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
Chalupa_Batman
Hello @JR63
There are no tracking number for ordering SIM cards directly from Public Mobile. You're basically at the mercy of Canada Post. You an either way for it or you can go buy one via the links below and Public Mobile will credit your account the cost of the SIM Card.
To get a new SIM card the fastest routes are these.
https://www.publicmobile.ca/en/bc/pick-up-SIM - Find a local store in your area.
Amazon - Here you can get it cheaper and maybe a few days wait $4.99
Or find a Mobile Klinik near you. https://mobileklinik.ca/stores/
