Sim
nel_g
purchased an new sim card from telus, inserted into new Apple iPhone 11 activated Public sim and ported my number no problem. when phone comes on it says SIM Not Supported. Went back to the Mobile Shop where phone was purchased and they tell me the issue is with Public Mobile and good Luck trying to fix it.
hycm53
Which Mobile shop? Is it trustfully shop? According online search, your iPhone is locked. You'd go to the Mobile shop ask them to unlocked or return the phone if you could.
When your iPhone says SIM is not supported, it usually means that your second-hand iPhone or even a new iPhone is locked to a carrier. You can go to Settings > General > About > Find Carrier Lock and check if it shows No SIM restrictions, then your iPhone is unlocked.
Dunkman
@nel_g
You can also try the PM SIM card in another working phone. That would help determine whether PM service issue versus hardware set up problem.
@nel_g yes, it could be just a sim provisioning issue.  Easy fix for PM but you need to open ticket to engage support
1. Please open ticket via Chatbot (requires access to My Account): click this  Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
