Sim
BrunoJoel
Bought a sim card and paid for it for my wife's phone. Its been more than 10 days? What do I do? Cancel through credit card?
CSA_PM
Customer Support Agent
Hello @BrunoJoel,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Filing a dispute without first working with the merchant to resolve the situation would violate your credit card terms of service.   Please work with Public Mobile to get the SIM card replaced.  I have asked Public Mobile to contact you.
slusagm
it can be 1 to 3 weeks, so you should get it later this week
but ask PM to check if you like.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
hi @BrunoJoel
  Sim card delivery can be 3 days to 3 weeks here
But best to ask PM support agent for status update, you can  submit by direct message:
Better to ask if you can pickup another one from a nearby Telus or Koodo store instead of wait longer to have them resend a new one
