Sim
KPLi
I'm a new member. There is now a discount of $5 per sim. The post office is on strike and it is impossible for me to receive the sim. Can I go to the store and buy one for $10 ? Then apply for a refund of $5 ?
hairbag1
@KPLi
check to see if there's a Mobile Klinik in your area, as they usually have the PM sims for about $10. If you do find one, then after activating your new account, message Customer Support to request credit to your account for the cost of the sim.
@KPLi  Yes you can get SIM cards
Find SIM card Find a store near to you | Public Mobile
Amazon
Public Mobile Prepaid SIM Prepaid Phone - (Universal/SmartPhones), Packaging May Vary : Amazon.ca: E...
only $4.99 Amazon and ask support if the will reimburse you for picking one up in your own
also it’s good to have spare sim on hand anyways incase you lose or damage yours or to give to family  or friend to join PM and use your referral code to reward both accounts win/win
send  a  private message   To CS_Agent
HI @KPLi
Public Mobile has arrange for another courier to ship the sim card if you want to still order from them
However, you can go to pick one up from Telus or Koodo store for $10 or from Amazon for $5
 Telus or Koodo or Mobile Klinik store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
 and yes, you can try to ask for reimbursment.  you can submit  ticket by direct message:
