08-28-2023
05:05 PM
08-29-2023
12:13 AM
computergeek541
08-28-2023 05:37 PM
Where did you order them from, Directly on the Public Mobile App?
08-28-2023 05:13 PM
Personally, I would recommend you retain it if you're remaining a Public Mobile customer.
Always a good idea to have a spare one around for potential lost of use of the original.
And they never 'expire' or wear out (especially in original packaging).
08-28-2023 05:10 PM - edited 08-28-2023 05:20 PM
@Sxnz wrote:How do I cancel a sim if i brought 2
@Sxnz , if it turns out that you are unable to cancel one of the SIM Cards you can save it as a spare in case one gets damaged or lost. Or you can pass it onto someone you know that can use your friend referral code for a one time $10 credit off their bill & you will receive 1 point every 30 days (from your renewal date) they stay with Public Mobile with an active subscription 😉
08-28-2023 05:06 PM - edited 08-28-2023 05:07 PM
@Sxnz Seeing as SIM cards are not refundable . You have to contact support and see if it can be stopped before it ships out . But it’s good to have an extra SIM card on hand In case you lose or damage it . And also for friend referrals too .
private message To CS_Agents click
VVVVV Link below VVVVV
