10-14-2025
04:10 PM
- last edited
a month ago
computergeek541
Hello,
my sim is unregistered on my Samsung GALAXY FE. MY ACCOUNT IS ACTIVE AND SUBSCRIBED BUT MY LINE ISNT CONNECTING TO THE TELUS NETWORK. PEASE REPROVISION OR REACTIVATE MY SIM.
THANK YOU
a month ago
I was abroad and came back.. all your suggestions failed and no clue what to do!
10-14-2025 04:30 PM
@Nali1 wrote:Hello,
THANK YOU
Hello @Nali1
You can try going into your Network Settings and reset them. You can also take your SIM card out of the phone, try your SIM card in a different phone, restart the phone and that helps reprovision the SIM sometimes. If that works, take the SIM out and place into your phone.
10-14-2025 04:21 PM
is that a new activation or a new phone?
if it is a new phone, please check if the phone is blacklisted here
https://www.devicecheck.ca/check-status-device-canada/
if the account is newly activated, then it should be just a sim card provisioning issue. Easy fix for PM support and you just need to engage them by direct message. Private message CS Agent at:
