05-09-2026 05:09 PM
I'm unable to sim swap as I can't do 2fa. Code always sent to phone. Email not an option. What do I do?
05-09-2026 05:50 PM
Try to see if you can get the 2FA code via email or voicemail:
On the 2FA screen, click "Didn't Receive code" or "Resend Code" and choose "Send email" or "Send Voice Message" to get 2FA.
(When choosing "Send Voice Message", call yourself using another phone to retrieve VM. Press * to interrupt the VM greeting and then enter the VM PIN )
If still unable to get the 2FA code, you will have to engage PM support by direct message. Private message CS Agent at:
