07-25-2022 10:00 PM
@I have a sim card that was already activated but I don't know the 4 digit password how do I find out what it is ?????
07-25-2022 11:52 PM
07-25-2022 11:29 PM
so when you call *611 to purchase some add-ons or make payment or add it a voucher, you need
that is call 4 digit pin account, if you don't have it as mention by @softech above, to contact to CSA, to reset,
but if you can Login Page to your account also you can change by yourself,
here the support team by CS_Agent
07-25-2022 11:24 PM - edited 07-25-2022 11:27 PM
the 4 digits PIN for 611 access can be reset by logging into Self Serve My Account, Profile page, click on PIN and you can reset following the next scree
07-25-2022 11:16 PM
The one that u need when u phone 611
07-25-2022 10:57 PM
@Dee95 1234 is rarely the password, open the ticket with PM suppoelrt for SIM card PUK as I advised above
07-25-2022 10:57 PM
what you try to do for this password.
07-25-2022 10:56 PM
The password is not 1234
07-25-2022 10:55 PM
07-25-2022 10:05 PM
@Dee95 The default PIN for PM SIMs is 1234 but not sure if that is the PIN you are asking about.
07-25-2022 10:02 PM - edited 07-25-2022 10:02 PM
@Dee95 the unlock pin for the sim card? You can open ticket with PM for the sim card PUK
Use this direct link to open ticket with PM Support
