How do i get time online
Alexwren1975
@Alexwren1975 wrote:
How do i pay for time online
self solution removed
HI @Alexwren1975   solution chosen already?
to pay online, just login to My Account and go to Payment page.  There , you can pay the Amount due or load any amount you want
If you know the 4 digits pin, you can also pay by calling *611.  (if you need the 4 digits pin, you can reset it by going into My Account)
HI @Alexwren1975   would be helpful if you tell clearly what are you trying to do.
If you meant you want usage history, login to My Account and there is a page for Usage History, which you can check the log for Data, Talk and Text
Alexwren1975
