Options
02-21-2022 01:51 PM
Options
02-21-2022 01:58 PM
Depending on the kind of device you have, also make certain you aren't trying to place the SIM card into a memory slot for a micro SD card.
Options
02-21-2022 01:54 PM - edited 02-21-2022 01:55 PM
Options
02-21-2022 01:54 PM
@agiudice You SIM should be a 3-in-1 sim that you can take the outer frame away, check it
