Sim card
02-03-2020 01:20 PM - edited 01-05-2022 09:19 AM
My Motorola phone died so moved my pm Sim to my other phone, a ZTE, but it keeps saying no Sim. It's in the tray properly and the chatr sim that was in there still works.
Phones
02-03-2020 02:35 PM
@Finman wrote:Thanks for the quick response. I should have clarified. Both are unlocked phones. The ZTE has only one sim slot, which works with the chatr sim. I'll get a new pm Sim and see if it works.
If your phone is older than 2 years and it was purchased from Chatr, it might still be locked to that carrier.
If you have a SIM other than Chatr, Fido & Rogers, you could try it out on your phone to see if it works. If that SIM does not work, contact Chatr to get your phone unlock code at no charge.
02-03-2020 02:30 PM
@Finman try this manually select PM as your network . Set it to flight mode . Restart your phone and take it off flight mode .
02-03-2020 02:24 PM
02-03-2020 02:11 PM
@Finman wrote:My Motorola phone died so moved my pm Sim to my other phone, a ZTE, but it keeps saying no Sim. It's in the tray properly and the chatr sim that was in there still works.
If the phone is compatible and unlocked, try using the SIM slot that you know is working. Try switching out the chatr sim.
02-03-2020 01:32 PM
02-03-2020 01:27 PM
What is the model of ZTE phone? Maybe it is not supported by PM.
