09-24-2019 10:37 PM - edited 01-05-2022 09:19 AM
Hi! My friend received the $10 balance and I didnt, I only got the $1 discount. Am I supposed to get the $10 too?
09-25-2019 11:56 AM
@TheStarkest if the referral doesn't meet the eligibility requirements, then no you won't get any additional credits. So if activated outside of the prom time period, and not activating a plan that meets the requirement then only your friend will get a $10 credit. You'll only get the $1 on going referral credit.
09-25-2019 05:59 AM
Only the person you referred will get the $10 discount, you will receive 1$ every month as long as the customer is with PM.
09-25-2019 12:07 AM - edited 09-25-2019 12:10 AM
@TheStarkestI think you are referring to below. Look at start date and plan required.
From September 23th until September 30th, 2019, you and your friend can each get an extra $10 credit (on top of the regular Referral perks) when you refer them to Public Mobile and they activate online. Plus, for each referral, you will receive an entry into a lucky draw for a chance to win 1 of 3 pairs of Cineplex General Admission Tickets, so we can take you and a friend to catch a flick that you love.
You | Your friend |
Get the full scoop below.
Taking advantage of this promo is easy. Just follow these steps:
As a Public Mobile customer you need to:
- Be a good pal and refer a friend to Public Mobile.
- Tell your friend that they need to successfully activate online on a $25/mo plan or higher during the promotional period and include you as their referrer in order to be eligible for the promotion. Learn more about Referral Codes HERE.
- The extra one-time $10 credit will be applied to your Self-Serve account within 72 hours of your friend’s online activation. In addition, you will continue to be eligible for the $1 referral credit off your monthly bill for as long as your friend stays with Public Mobile.
Your friend will need to:
- Purchase a Public Mobile SIM card. (Find a store)
- Activate a Public Mobile SIM card online on a $25/mo plan or higher at activate.publicmobile.ca.
- Enter your active Public Mobile referral code on the referral page during the activation process. The one-time $10 credit will be applied to their Self-Serve account within 72 hours of activation.
FAQs and terms and conditions are below. Happy referring!
09-24-2019 10:46 PM
@TheStarkest wrote:He actually activated it on Aug 29 using my code, and he just told me that he noticed he got a $10 balance (assuming he just checked his account just right now). But for me, I didnt get the $10 reward
You're not supposed to. That $10 is normally only for the new referred customer.
09-24-2019 10:44 PM
@TheStarkestYou won't get the $10 reward.. only $1 per month as long as your friend is still have an active account.
09-24-2019 10:42 PM
09-24-2019 10:39 PM - edited 09-24-2019 10:40 PM
@TheStarkestIt depends when your friend activated the account, for you to get the $10 your friend had to had activated between after September 23. (yesterday).
Public Mobile deals are time sensitive.. have to be strike just at the right time.
