04-24-2025 11:11 AM
04-24-2025 08:00 PM
04-24-2025 11:41 AM
@Davybaby wrote:Plus I cannotook this I fo up with the simcard locked
hi @Davybaby
even with the sim card lock, you can message support agent for help. Just click on this link to message PM support agent for help
04-24-2025 11:39 AM
04-24-2025 11:37 AM
It doesn't work
04-24-2025 11:37 AM
and do you have a Samsung phone? you might want to check with Samsung at 1-800-726-7864 for a device PUK code.
04-24-2025 11:35 AM
O do not remember doing that
04-24-2025 11:35 AM
hi @Davybaby
better try the sim card on another phone first and see if it works
but of course, you can also open ticket with PM support and have them to check if the PUK code they provide can help
you can submit ticket by direct message:
04-24-2025 11:34 AM
I have insert the Sim back in the phone to see it
04-24-2025 11:33 AM
I do not remember doing that
04-24-2025 11:32 AM
hi @Davybaby
did you ever set a PIN for sim card? if not, it won't be locked out of the blue
can you show us what the message was when asked the PUK? there are different messages and it means different things
04-24-2025 11:30 AM
It is
04-24-2025 11:29 AM
It asked for a digit pin #
Then when I tried it locked
04-24-2025 11:27 AM
hi @Davybaby
you are certain it is a Sim card lock? what was the error message?
Try the sim card on another phone to see if it works, that will confirm if the lock is on the sim card or if it is in fact a device lock. If it is a device lock, PM support won't be able to help
04-24-2025 11:14 AM
@Davybaby If it’s SIM card puk support can help
04-24-2025 11:12 AM
PM can help if it is a sim card lock and sim card PUK is needed
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
