09-17-2024
12:31 PM
09-17-2024
02:53 PM
computergeek541
09-17-2024 12:43 PM
hi @Millions
yes, you can. Easy process
After you got your sim card, login My Account, then go to Profile page and click the pencil beside sim card number and update it.
if you cannot login My Account, then ask support agent to help to update the sim card number for you
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
