05-11-2023 01:36 PM
Hello
I swapped out a new sim card as I couldn't find my original. I went online and registered the new sim. Unfortunately it is not working How do I get someone to fix this? Thanks
05-11-2023 06:50 PM
@leesor oh, you used another time before.
would be good to click Reset All Networks and then go to the VPN screen on your phone and delete all VPN profiles
05-11-2023 06:49 PM
Have a go at doing a network reset. What make and model phone is it? It might be that it still sort of thinks it would like to keep talking to your other service.
05-11-2023 06:46 PM
Yes numbers match. I did use a different sim out of the country for 7 weeks
05-11-2023 06:31 PM
And when you view the sim # in the account all the numbers agree with the physical card in your phone?
Away, like out of country? Did you use a different service wherever you were?
05-11-2023 06:28 PM
Yes the account is active. I was away for six weeks. I powered down the phone. I even tried to put the sim in another phone. Not working there. I tried to call my number from another phone and it went to voicemail.
05-11-2023 06:23 PM
@leesor if you go back to Profile page of My Account, check the sim number, does it shows the new one? if so, reboot the phone once
And if that does not work, look like time to get support involved
1. Please open ticket via Chatbot (requires access to My Account) using direct link: https://publicmobile.ca/chatbot.
Start by typing "Contact agent ", then click "Contact Us", then click "Other", click "Click here to submit a ticket ↗""
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
05-11-2023 06:22 PM
So it seems that the service is not working to begin with. Is the account active? Have you done a full power down restart? Is this a different phone of the one your previous sim was in?
Are you connected to Public? Can you call in or out? Text in or out? Browse the internet on cell data (not wifi)?
05-11-2023 06:18 PM
I attempted to change the sim number in desktop mode. The system says I cannot change to the same sim. It seems the change was accepted in mobile and will not allow me to resale as per your instructions
05-11-2023 01:58 PM
OK thanks I will try that and repost if that doesn't work.
05-11-2023 01:38 PM
@leesor The key is to use a desktop or laptop to request change sim card and NOT on mobile phone as there is a problem with this portion of the mobile site, so, it won't work on mobile phone or tablet
Login to My Account using only a desktop or laptop computer Click Quick Links and then click Change SIM card, enter the new sim card number and complete the step
https://selfserve.publicmobile.ca/en/account/edit/your-account
