Sim card number
JD76
My Sim card number is not accepted on registration. What donI do?
hi @JD76
yes, most numbers can be ported into Public Mobile. So, no worries on that
when you subscribe, you need a brand new new used Public Mobile sim card.  If you don't have one, cheapest to buy from Amaozn.ca for $5 o buy in person from Telus or Koodo or Mobile Klink store for $10 (or you can also use eSIM if your phone supports)
after you have the sim card, download PM app on the phone and start the subscription process there
JD76
I am trying to transfer my number into PM?
Thanks
hi @JD76
first, tell us what you are doing. We are confused, we just say your sim card is not accepted in registration
are you existing PM customer? your lost your phone and need to get a new sim card?
or you are getting new account and trying to transfer your number into PM?
JD76
Will I be able to keep same phone number?
@JD76
I would suggest you order another one from Amazon at $5 with faster shipping.
hairbag1
@JD76
has it been used by somebody else ? Sims can only be used 1 time. If yours has been used before, you'll need to get a new one.
