07-10-2022 01:14 PM
07-10-2022 01:45 PM
I came back from travel, forgot my sim card in my other house overseas.
07-10-2022 01:20 PM
@Linaal-nazzal What error does it show?
do you have another phone? you can try to put the sim in another phone. That can force a provision of the sim/account account and you could fix it yourself
even without another phone, try to reseat the sim card first (power off the phone, remove the sim for a minute before putting it back and power on)
Of course, if none of that works, open ticket with PM support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
07-10-2022 01:20 PM
@Linaal-nazzal hello why did you need to change sim? was it for a new phone?
07-10-2022 01:17 PM
@Linaal-nazzal hi turn off phone reseat sim restart phone if it doesn't work
you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
