Sim Issue
Salem
How to register my new sim
@Salem
You could try to click this link to use the: Public Mobile Online Activation Assistance
BlueB
@Salem
Are you having a problem with activating a new SIM card?
If you're swapping SIM cards from another one that is active with Public Mobile, follow the instructions that @softech provided.
If you have a new SIM card where you want to activate a new account, then you can access it via: https://activate.publicmobile.ca/  A few things to note:
  • Easiest to activate with a Public Mobile phone number (first), even if you want to port over an existing service/number
  • Porting/transferring an existing number can be complicated - keep the old service active (ie. do not cancel it)
  • Each email account can only support 1 Public Mobile account... if you have an account already associated with your email address, you'll need to use a different email address for a new account
  • Look for activation promos for extra ___ (usually bonus data) to get the most out of your new service
  • Use a referral from a friend/family member (or an existing account you have) to get $10 credit on activation, and the referrer will get $1/mo... we're all users here with referral codes but always best to help out a friend/family member
If we're missing anything, just let us know!  🙂
@Salem   you can request SIM swap on My Account yourself:
Click on Change Sim card, then enter the new SIM number and select the 2FA you want to receive
