Sim Card Did Not Arrive
CanadianWoods
I ordered a physical sim card. It has been three weeks and it has not arrived.
How do I pursue a refund?
Jeff
2 REPLIES 2
Socrates8567
Sometimes, sim cards mailed by public mobile via Canada post can take longer. Sometimes up to 4 weeks.
If you purchased a plan you really like and think it is worth keeping, you can purchase a sim card three other ways.
https://www.publicmobile.ca/en/bc/pick-up-SIM
Amazon for $4.99
https://mobileklinik.ca/stores/
When you have registered the new sim card, just contact customer service with a copy of your reciept and you'll be credited on your account.
slusagm
Three weeks is too long.  Please ask PM to check, they will either resend or ask you to buy in person from store and reimburse you
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
