01-26-2026 09:46 PM
Hi there,
I signed up for Public Mobile services; I tried selecting a phone number for my new plan and after it kept spinning just gave an error contact an agent. I did contact CS_Agent.
What I did notice I'm unable to login via the app now. Not sure what happened?
Hopefully they can help. Thanks!
01-26-2026 10:35 PM
@hTideGnowThe app is in Maintenance Mode. I have zero access to MyAccount even via website. I was also double charged. They double charged me $11.30. This isn't looking good and I literally just subscribed.
01-26-2026 10:13 PM - edited 01-26-2026 10:13 PM
@hTideGnow Yeah I figured for $20 plan might as well join now. Within the next 2 years hopefully something new will pop-up.
01-26-2026 10:07 PM
01-26-2026 10:07 PM
@hTideGnow I am keeping my 2 lines with Freedom Mobile. The only reason I'm forced to come back to Public because there's a possibility I might be moving from Ontario again to Lake Louise AB. And that area in Alberta has no Freedom coverage. If I roam for more than 3 months Freedom would terminate my services.
01-26-2026 10:05 PM
hi @ipro32
too many people using it now 😞
so, were you with PM last year and come back for the good deal?
01-26-2026 10:04 PM
@hTideGnow I think I was able to register the eSIM to my SIM2 slot on the S25+. Unfortunately, right now the PM app shows "Maintenance Mode".... "App under maintenance".
01-26-2026 09:55 PM
@hTideGnow I reinstalled the app. Now its saying "Estimated wait time 5min" I'm in the virtual waiting room.
01-26-2026 09:52 PM
HI @ipro32
yes, you can , i think S25+ allow dual active esim
01-26-2026 09:52 PM
@hTideGnow Its gives error "ESIM NOT INSTALLED" "Something didn't go right while installing your eSIM"
01-26-2026 09:51 PM
@hTideGnow I have a Samsung S25+ and right now I have a Freedom eSIM on it. Should I be able to add a Public eSIM to the 2nd IMEI while maintaining the Freedom eSIM on SIM1?
01-26-2026 09:49 PM
