11-05-2023 01:11 AM
I have been a long-time customer and signed up my child for the basic $15 plan in September and didn't get the $10 dollar credit and the number wasn't added to my refer a friend even though I entered my code for the first two billing cycles. I try to start a chat and it seems impossible to get anywhere to get this resolved. Is there a mod on here that can help me out?
11-05-2023 01:19 AM
The chatbot is broken. Send a private message. Leave a detailed message and include your referral code to be added to your child's account. You can include the verification info in your initial message or wait for the CSA 's reply to verify both accounts. If you do include it in your private message to the CS_Agent thuis is what they require.....
To send a private message to customer support use the link below....
Check your private message box in the morning for a reply.
11-05-2023 01:17 AM
You can contact an agent:
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
