09-04-2021 08:54 PM - edited 01-06-2022 03:24 AM
How is network signal in elevator, basement and subway?
09-04-2021 11:23 PM - edited 09-04-2021 11:25 PM
for TTC.. as far as I know. .only one company won the contract for 20 years and Freedom is the only license carrier for the company.. And, of course I meant the underground portion of TTC.. and of course, I don't meant stations who can get some weak signal from nearby PATH or buildings basement. 🙂
09-04-2021 10:01 PM - edited 09-04-2021 10:05 PM
@softech wrote:@VB1 not Toronto Subway for sure... currently only Freedom has signal within TTC subway
This really depends on the particular station and location. There are outdoor locations that do have signal. There are also some underground indoor signals that will sometimes have sporadic signal, although I'll agree that it can't be relied on
As for elevators and basements, there really isn't any way to accurately answer this question without knowing more specifics. At any particular place, you could have signal or you might not. There are many factors including the building's material, the location, and the proximity of the nearest tower.
09-04-2021 09:21 PM
@VB1 every elevator and every basement is different. So many variables.
Who are you currently with? Where are you located? (Assuming Toronto because you didn't say metro nor SkyTrain) Your own experience will be the best answer as there are only two main networks bell/ Telus and Rogers.
09-04-2021 08:57 PM
Thanks Elevator and basement?
09-04-2021 08:57 PM
Same as Telus bell Koodo and virgin and lucky. So if you are on one of those providers you will see no difference.
To answer your question depends on the elevator subway and sometimes your phone.
09-04-2021 08:56 PM - edited 09-04-2021 08:57 PM
