01-05-2016 11:54 AM - edited 01-04-2022 12:48 PM
01-31-2020 02:38 AM
@Simikarostron20 wrote:
I can't access my network and I don't know how to sign into network.
Can you provide more details so we can help you?
Did you just join?
When you say can't sign in are your trying to sign into your self serve account? Do you get an error message or anything?
Or are you saying your phone won't connect to network? What kind of phone do your have?
The more details and explanation you provide the more we can understand the issue.
01-31-2020 02:35 AM - edited 01-31-2020 02:36 AM
I can't access my network and I don't know how to sign into network. I need a little help
02-23-2019 01:31 AM
IT WORKED!!! PHONE IS WORKING AGAIN THANK YOU !!
02-23-2019 01:15 AM
@Outinspace11 wrote:I've been a customer for almost about half a year now and the last time I added funds to my account everything worked out perfectly, except this time I didnt add enough and had to change my plan to a little bit cheaper one and my phone never hasnt worked, data is turned on and I never changed any settings so I dont know why it would be any different
Ok. That's what made me think to throw in the last bit of my reply.
Try the lost/stolen feature.
Log in to self-serve. Plan & Add-Ons from top menu. Lost/Stolen Phone from next menu. Suspend Service button. Log out. Wait a few minutes. Log back in and back to Lost/Stolen Phone and Resume Service this time. Log out. Restart phone.
See what happens.
02-23-2019 01:14 AM
02-23-2019 12:57 AM
@Outinspace11 wrote:I'm having this same issue with my galaxy s8 and I'm supposed to have 5 gigs of data and I just paid 40$ 2 days ago and it didnt even turn my data on for a second, so I've spent 40$ and not even been able to use my data at all, if I use my phone it has to be on wifi
Data mode on?
APN settings?
Officially Recognized APN Reference
Or what might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
See what happens.
02-23-2019 12:57 AM
@Outinspace11 first does the data addon show in self serve?
Are you a new or old customer? If New did you set up your apn correctly?
Is Data turned on?
02-23-2019 12:50 AM
01-14-2016 07:55 PM
LOL...
I tried inserting an image, but that functionality seems to be broken on this forum
So here's the link instead: https://i0.wp.com/media.tumblr.com/8c916157c252b080f3da41c361d19890/tumblr_inline_mkwvyxkXYj1qz4rgp....
01-14-2016 07:49 PM
Check your mailbox every 30 minutes until it arrives!
01-14-2016 07:07 PM
Oh I'll totally settle for that - kind-natured as I am
01-14-2016 03:18 PM
Or a Roam Mobility SIM? hahaha.
01-14-2016 03:12 PM
No worries, @srlawren - but you do owe me a beer now
01-14-2016 02:59 PM
@sparky2015 wrote:Yes correct it was the app that was using up my data and nothing to do with with my data limit that I had set on my phone.
And I was so sure... oh well, I've been wrong before, and I'll probably be wrong again..... 🙂
01-14-2016 02:57 PM
01-14-2016 02:22 PM - edited 01-14-2016 02:23 PM
@sparky2015 wrote:What I found out was that I had a app called exchange services that was using up all my data as it was running in the background. So what I did was to disable bachground data on cellular networks so it isn't using my data up.
Glad to hear this was resolved!
I had a similar issue when I was with my previous wireless provider. When setting up MS Exchange on Android (at least previously) the default was to sync EVERYTHING, and it would do so even when "sync" is turned off on the Android system - I went through 300mb in a couple of hours without knowing it and ended up getting extra charges on my bill.
At least with PM, no extra charges - but of course no data
01-14-2016 01:30 PM
@sparky2015 thanks for the update, glad you got it sorted out!
01-14-2016 12:47 PM
@sparky2015 Just to clarify, you're saying your entire PM data bucket was used up. So this had nothing to do with the data limit you set on your Android phone itself?
01-14-2016 12:08 PM
01-13-2016 09:31 PM
Hey @sparky2015, has this been resolved yet? Would love to know what the resolution was!
01-06-2016 11:47 AM
01-06-2016 11:32 AM
@sparky2015 From your description, this sounds like an account provisioning issue with PM (phone data limit would not lead to a sign in page). Please get in touch with PM support right way. Since you're a pioneer customer, you can simply dial 611 to reach PM support. You may have to be persistent with the rep to let them know all the steps of troubleshooting you've been taken through on this community.
Let us know what you find. All the best!
01-06-2016 10:46 AM
01-06-2016 08:09 AM
01-06-2016 07:47 AM - edited 01-06-2016 07:57 AM
Have 1G of data and have used 0.78G so far
01-06-2016 07:42 AM
Moto g
01-05-2016 06:54 PM
@sparky2015 Please confirm how much data you have as part of your plan, and how much of it is remaining in the current plan cycle.
01-05-2016 05:09 PM
Yeah if this is a phone and SIM that were previously working fine then it's possible that your data allotment has been used up... Or, if you don't reboot your phone regularly, I'd definitely suggest that as something to try. It only takes a few minutes and can often resolve "weird" phone behaviour.
PS. what make and model of phone is that? It's obviously and Android running Lollipop or Marshmallow, but knowing a bit more info might help.
01-05-2016 04:21 PM - edited 01-05-2016 04:21 PM
Could be related to APN setting or your plan does not have any data left?
01-05-2016 02:54 PM
unable to surf the web unless I'm connected to wifi
