Shortcode
10-01-2019 09:16 AM - edited 01-05-2022 07:22 AM
I found the shortcode in the master list but still cannot send or receive text?
Joining Public
10-01-2019 10:19 AM
Some shortcode texts doe work, while others don't.
Here is a list (not sure if it is the most up to date)
10-01-2019 10:00 AM
@mtse1 I know show short codes from certain banks and stuff don't work with public mobile. You can search it in the community and you'll find info about it
10-01-2019 09:53 AM
i meant texting
10-01-2019 09:53 AM
shortcodes are strictly for testing purpose
10-01-2019 09:46 AM
Iphone 8
10-01-2019 09:46 AM
shortcode is a set of numbers (usuaLLY 5) that is not a phone #, usually used by banks etc.
10-01-2019 09:40 AM
Which phone are you using?
Does calling and/or data work?
10-01-2019 09:21 AM
@mtse1 what do you mean by shortcode? Can you call in and out but not text?
