Supported Short Code not working
shankle44
I joined PM and everything is working great except I can’t receive shortcodes from my workplace. I get shortcodes from other places, banking as an example. The service we use is Everbridge and the shortcode is 89362.
Any ideas?
Thanks in advance,
Shawn
@shankle44   usually is one week of wait for all the Canadian shortcodes to come
is that a 2FA from  Canadian financial institutions?  Start with them , ask them
You can also open ticket with PM Support and ask them to check
But if it is from an overseas banks, it might not work.
to open ticket with PM Support:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
shankle44
What would the next step be once I am after 5 business days and still not receiving these short codes?
@shankle44   shortcodes or most 2FA texts are A2P messaging.  Application to Person.  It usually take longer for those system to learn that you have changed your provider  (porting) and route the text to you correct.    Different systems take different length of time.  So,expect a full week before you will be getting all A2P/shortcode messaging
HALIMACS
Give it a week to enable the service provider change to implement,  @shankle44
LoveNature
Hi @shankle44
is take for 3 to 5 business day to get those code.
