Setting up
_blondie
It keeps sending a code to a number that can’t be in service yet to verify the identity
@_blondie was it trying to send to a new number you chose or a number that you have no idea?
Check if your PM sim already setup and able to connect to the Public Mobile network and able to receive the code
If still have trouble with the validation, please message support
Is there an option for didn’t get code ? If so tap it it should give option to send code to email instead . If still no luck please submit ticket with support
send a  private message   To CS_Agents click
_blondie
I’m trying to set up the eSIM but the code is going to a number that we can’t access without said code
