11-26-2020 01:25 PM - edited 01-05-2022 04:15 PM
I just activated the SIM and account today and haven't received any services. What is wrong as I am supposed to receive coverage where I am.
11-26-2020 01:31 PM
Log into your self serve account and check the status ? Try shutting down your phone and restart it.
11-26-2020 01:34 PM - edited 11-26-2020 01:37 PM
@bevjw15 wrote:I just activated the SIM and account today and haven't received any services. What is wrong as I am supposed to receive coverage where I am.
Try some of these: reboot phone, reset network settings, take sim card out and put back in, put on airplane mode then take off and reboot, put in lost/stolen mode in self service then take off and reboot.
Is your phone unlocked?
11-26-2020 01:36 PM
Are you porting a phone number? If so, it might take awhile and you won't have service until it finishes porting.
11-26-2020 04:14 PM
@amy303 wrote:Are you porting a phone number? If so, it might take awhile and you won't have service until it finishes porting.
That's not the case. When porting in a number, the Public Mobile service is supposed to work immediately, although incoming calls and text messages from carriers other than Telus will continue to go to the old carrier's service until porting is complete. Since the Public Mobile service doesn't work at all, there is something else that is a factor other than number porting.
11-27-2020 06:39 AM
Tried that of course there are no bars showing as in no connection, been having this problem since account started.
11-27-2020 06:45 AM
Which phone model are you using? Is it possible the netework could be set to only connect to 2g?
11-27-2020 09:21 PM
@bevjw15 what's the make and model of the device?
you can contact customer support mods here
type "no service"
(use the chat bubble options, then click "click here to submit a ticket!)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
