11-23-2019 06:56 PM - edited 01-05-2022 08:06 AM
11-23-2019 11:45 PM
@Maremasl wrote:My texts ain't sending?? Why
Are you a new customer or did you recently switch to a different phone device?
If either of those are the case, ensure that your SMSC is set to +16475800172.
11-23-2019 07:54 PM
If you are using an iPhone, check the iMessage setting which may be preventing you from sending out text message.
11-23-2019 07:16 PM
Try cycling phone off / on. Let us know if that works.
What plan are you on ?
11-23-2019 06:59 PM
More details will be helpful.
New customer versus old?
Which plan?
Did your plan renew?
Did you port your number?
