11-24-2023 12:42 PM
My service with Public Mobile does not work properly. I am not receiving messages and calls. I cannot get any help with this issues. Can I talk with a representative, not robot?
11-27-2023 03:56 PM
Thank you for your help. All was fixed.
11-24-2023 01:04 PM
@Lioudmila1 Yes call them, assuming this is a porting problem they should be able to fix it.
11-24-2023 01:03 PM
Yes, I see the number. Thank you! Can I try this number?
11-24-2023 01:00 PM
@Lioudmila1 Did you check your community inbox for the porting team phone number I sent you?
11-24-2023 12:59 PM
Two days ago. I confirmed the transfer with the previous provider.
11-24-2023 12:57 PM
Yes, I am subscribed
11-24-2023 12:51 PM
When logging into your account and selecting the Payments option, does it mention that you are subscribed?
11-24-2023 12:50 PM
When did you do this transfer? Did you leave the old sim in a phone to confirm the transfer?
11-24-2023 12:50 PM
I tried so many times and failed because always I had an error. Tried again and again as a horse following a circle.
11-24-2023 12:47 PM
I don't believe Public Mobile as a contact number for support. However, you can submit a support ticket by clicking on the "Click here to get started" link on this page: https://www.publicmobile.ca/en/on/send-us
A support member should get back to you as soon as they are available.
11-24-2023 12:46 PM
I transferred a number from a previous provider. My phone worked yesterday and before yesterday, but today I found this issue
11-24-2023 12:46 PM - edited 11-24-2023 12:50 PM
@Lioudmila1 Check your community inbox in a few moments, I will private message you the porting team number. You will find it at the envelope icon top right or click on your avatar and select Messages.
11-24-2023 12:45 PM
Yes, I can call out and do not receive calls
11-24-2023 12:44 PM
@Lioudmila1 Did you just join Public Mobile and port in your old number? Can you call out but just not receive?
11-24-2023 12:44 PM
When did you sign up? Did you get a new number or did you transfer a number from a previous provider?
