Service not working since changing plan today
pamorin2
Can somebody help me?
pamorin2
was charged, plan looks active in portal. rebooted and all that stuff, but no other phone to test.  Phone works on wifi and this happened on the day my plan changed.
@pamorin2
This issue happens sometime after a plan change
So, is it not connecting at all?
First, make sure PM charged you and renew you on the new plan
Try reboot the machine once
Try to reseat the sim card.  Power off the phone, take sim out and wipe it clean and put it back and power up
if nothing work, message support here
@pamorin2  First try rebooting the phone . Or reset network settings . Is it possible to try the SIM card in another phone . If still no luck . Please submit ticket with support to help you fix
private message   To CS_Agents click
