Service in Mexico
03-13-2024 01:56 PM
I will be going to Mexico in a couple of weeks. I’m wondering if Public Mobile has a plan I can use in Mexico. Do I need a different SIM card?
Service
03-13-2024 10:14 PM
Thank you.
03-13-2024 02:29 PM
03-13-2024 01:59 PM
@oceanblue Sorry PM only works in Canada and the U.S. with roaming add on , your best to get local SIM card in Mexico for your trip .
03-13-2024 01:58 PM
hi @oceanblue sorry, PM has no roaming service in Mexico. You need to use local data sim or travel esim
For calls, use VOIP app Textnow to make calls using the app on wifi and local data
03-13-2024 01:58 PM
no PM service in Mx. Try using WhatsApp for calls / tetxts using your local wifi.
