03-29-2023 04:50 PM
Text and data are not working. My account is active and I have followed troubleshooting steps.
03-30-2023 10:19 AM - edited 03-30-2023 10:28 AM
@iamcdn wrote:@LitlLdy How do you reset network settings?
EDIT: nevermind, I found it.
@iamcdn , sorry I was asleep. My phone is an iPhone so unless yours is also I wouldn’t have been able to tell you where it is.
Did it fix it for you? If not make your own post & other customers here will try to help you. If not please submit a support ticket & a CSA tech will fix it for you. You need working phone service.
Edit:
03-30-2023 09:08 AM - edited 03-30-2023 09:10 AM
03-29-2023 07:20 PM
03-29-2023 06:33 PM
03-29-2023 06:24 PM
Resetting the network settings worked! Thank you!
03-29-2023 06:08 PM
@Egillis wrote:No, after re-starting I can't connect to the network at all. I'm located in Calgary.
@Egillis , have you tried resetting network settings & rebooting to see if that helps? You will need to add you WiFi & Bluetooth again after rebooting if you use them. Also, if that doesn’t help turn phone off & remove SIM card from phone for 5 minutes then put it back in & turn on phone to see if it helps.
03-29-2023 05:29 PM
03-29-2023 05:28 PM
Hi, I've restarted, re-connected to the network, confirmed my account is active and that I have data available. I'm now unable to connect to the network at all, therefore cannot make calls.
03-29-2023 05:16 PM - edited 03-29-2023 05:19 PM
Try restarting your phone. After a restart mine works now
03-29-2023 04:56 PM
We might have the same issue. Can you make calls? Where are you located?
03-29-2023 04:56 PM
@Egillis what troubleshooting steps you taken?
and voice is working for bothin incoming and outgoing calls?
did you try to change the Preferred network type or Network mode to 3G and see if it helps?
did you login to My Account using Incognito mode to confirm if you have any data left?
let us know the result
