Secrtiy quetion
Theframemaker
hi i am trying to change auto payment but i forgot passward and secrity quetion.
how can i reset?
@Theframemaker   If you are unable to get through the security question for resetting password, you will have to open ticket with PM using Chatbot on the lower right
type: Forgot log in information
Click "Contact Us"
Click "Click here to submit a ticket"
There, you will be prompted to enter COMMUNITY Login (NOT My Account/Self-Serve) to validate your identity,
After ticket successfully opened, keep checking your Community inbox (envelope icon on top right)  CS Agent will communicate with you there
@Theframemaker
Explain your issue to Contact Customer Support Agent by  ,
they can solve your issue, they are nice Service Team they will help you 100%.
you will say forgetting and they will Reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started.
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
         Good Luck....
how can i reset?
Open up https://widget.telus.tiia.ai/publicmobile/publicmobile.html and then type in "forgot security question answer".
