Saving voicemail
clifft66
How can I save a voicemail or transfer it to my desktop?
2 REPLIES 2
hi @clifft66
there is no way to do that.  You have to download some kind of app on the phone and record the voicemail using the app
Chalupa_Batman
There really isn't a way. However, you can download an app like Record It! which will record what you're watching on your screen including video and audio. Then you can transfer that to your desktop. If you want to make it just an audio clip, there are several online sites that can do so.
